Hamburg PD
BTFire21
NY
Hamburg PD switched over today to their licensed frequency of 460.3375 with a DPL of 343. The 454.1875 temp frequency is not being used any more.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Thanks very much for the update.
I have editted the database to reflect this change. :cool:
glock2122
Does any one know if Hamburg PD input ch 465.3375 have a diffrent DPL number then 343 ?
BTFire21
NY
Just curious why you need the TX DPL ? If you are allowed to TX on the frequency I am sure the police dept could provide you with the DPL.
glock2122
I'am having a with my scanner on the 460.3375, Buffalo PD A&B District ch 460.350 splaches in. I only recive dispatch at this time I want to see if Buffalo cars come in on the 460.3375 ch..
glock2122
Type/o error 465.350 issue with my scanner which I can use a tone codr..
glock2122
Do you know why I here a weard sound on Hamburg PD radio in between transmissions? Allmost sounds like a wisteling!
BTFire21
NY
It is something that is coming from one of their remote voting receivers that they have.
glock2122
Do all PD radios hear the noise my scanner has the DPL code and I still hear it!!!
Ben830
It seems that a another agency is using the same freq. but when that comes in it seems to be encoded.
It seems to occur more during the week. I am listening today on a Sunday and it works perfectly fine. I which there was a way to listen only to Hamburg Police and block out the other agency.
glock2122
If I use my veh scanner Buffalo Pd B Dist. will be picked up 460.350. I still hear the whistling between the transmissions! It sound like a whisiling i belive it may be the repeter I've been around radios for 30 years.
Thank's
killerv
I get that noise also. It sounds like a bleedover or something. that Buffalo PD frequency is very close. You would think that these agencies (or the fcc) would predict interference with such close frequencies (is that is the isuue). I tried using att on my bct15 but i'm too far from Hamburg.
Ben830
They said to switch over the digital freq. today. What is that freq.?
glock2122
It appears Hamburg PD made some reparis the noise is a lot better between transmissions!!!!!
Ben830
I am still hearing Buffalo police coming in. Is there anyway to stop this?
glock2122
So far I don't see a fix Buffalo's radio system has many reapeters! You need a scanner that can be programed with tone codes. A few years ago Buffalo had to change tone codes, because the Sharref's Dept. splashed over.
