prcguy
- Joined
- Jun 30, 2006
- Messages
- 18,980
- Reaction score
- 15,479
I've tested Hamsticks on 40m and 20m and actually had ok success on 20m once they were tuned. I was using a choke balun at the feedpoint and the dipole adapter was mounted to an insulated pole, further reducing problems.
I also had a Buddipole dipole setup for awhile before I traded it off. I only used it a few times due to the hassle of setting it up and tuning plus I have other antennas that are much easier to set up and provide better performance. The Buddipole dipole is similar to using two Hamsticks but they have a tapped coil for changing bands. It turns out the coils and resulting two antennas are slightly different making an asymmetrical dipole and this is done on purpose. Just like Hamsticks, the Buddipole dipole works ok for 20m and above but 40m is not so good. The simple ferrite choke balun supplied with mine was very inadequate and there was always lots of RF on the coax. The Buddipole is insulated from the mast.
The typical dipole adapter for Hamsticks is metal and if a metal mast is used the mast becomes part of the antenna skewing the tuning. I would always insulate the dipole adapter and use an effective choke balun right at the feed. You can make a great choke balun for a Hamstick dipole by purchasing an FT-240-43 ferrite core for about $10 and wrapping 9 turns of RG-58 coax through it. This will target roughly 12 through 30MHz or 20 through 10m.
thanks for comments! To "TheSpaceMan", you shared that the hamstick dipoles have worked well for you, how did you tune the antennaes and/or any probs doing this? Admittedly, I have no stand alone SWR yet(one on order from MFJ), and just going by the antenna tuner built in into the 450D. The ant tuner tunes well with only one hamstick installed with its whip and the other hamstick inserted without the whip(so is hollow). Someone suggested getting a balun to help isolate the coax and the assembly and thus minimize inteference with auto ant tuning, and I will most likely get that. Any other suggestions would help.... alas, this radio is keeping me busy after I do my "regular" work in the am! thanks in advance!!!
