Pro 107 Scanner
Dan,
I think you should try another scanner antenna, as I do not think the stock antenna for the Pro 107 is that effective and could be the real over-all problem. Try an Austin Condor BNC from Scanner Master. It should bring in all your stations better. I also have a Home Patrol and considered going back and getting another PSR 800. But, I use the HP for base and in my car with excellent results using two Spectrumforce SMA antennas with mag mounts - great little antennas. So, I am going to buy the swivel case and an Austin Condor SMA rubber whip for the Home Patrol and use it portable as well. Then I do not need two or three radios. The HP seems to have the best all around performance - even better than the PSR 800. What I really like is that at home or in the car I can instantly hold on a frequency, note what department it is and return to scanning quickly. Can't do that with any other radio as fast. Lastly, the database for the HP and the PSR 800 is the same RR database, so all radios will have the same information. Regarding the Seatac frequencies - if you mean the Air Traffic Control frequencies, then you can go to AIRNAV.com and put in the KSEA identifier into the search window of AIRNAV and that will bring up all the stats for the SEATAC airport. Scroll down to the frequency area and you can copy/paste all the ATC frequencies into the submit window for RR and make a submission. That will update in a few hours to a few days. Then the info will be part of the actual downloadable database. Before you do that though, be sure and enter those conventional frequencies into your Pro 107 using the software and listen to them for a few days to ensure you are getting all the traffic on them. Also be sure to check the existing RR database to see what frequencies are there or may be omitted before you submit them - you do not want to resubmit existing data. Post a reply on how you get along on this!
Rodney
