Handheld scanner with the loudest audio
rhrailfan1972
Looking for something with loud,clear audio. Not looking for something real expensive. Used and older is fine as long as it is not crystal controlled. Analog only is fine to since I will only be using it for railroad scanning.
rf_patriot200
Freeport, Illinois
You might find that a old commercial motorola or Kenwood portable will have FAR Louder audio than Any of the scanners available, that's why many Railfans use them for monitoring on trackside. Or a earpiece might give you the extra volume.
rf_patriot200
Freeport, Illinois
I shall look into those
With all the other microelectronics in most scanners, the audio amps are just not capable of much over 500-600mw of audio output to listen at trackside, unless you use some sort of earbud. Commercial portables are Designed for higher audio outputs as much as 2 watts of audio.
rhrailfan1972
In the car is where I have trouble hearing. Even with the windows up every scanner I have tried I can not hear it.
rf_patriot200
Freeport, Illinois
I just looked both those Motorola radios up and they say both are UHF
a727469
Maine
While not as “classy” as the Motorolas or Kenwoods, a basic old Icom v80 or similar vhf handheld would be good.
Trucker700
When I was driving over the road I brought along my SDS100 hooked to a scanner antenna mounted on the passenger's side mirror. Inside the Peterbilt truck I was driving I could barely hear it at full volume. I purchased a BC23 powered external speaker for it and hooked it to the earphone jack.
I had plenty of volume that made using the scanner much nicer.
It did add more wiring to my setup. But, with a bit of organizing, everything worked out well.
The speaker comes with a very long cord so it can be mounted in a convenient spot and not get in the way.
James
rf_patriot200
Freeport, Illinois
James
Yeah, that'll work if you stay in your vehicle, but doesn't help much if you're on foot. (y)
hill
Middle River, MD
I wouldn't get a XTS3000, as they are very old and take a older Motorola CPS to program and may need a RIB box or you can find RIB-Iess cables for programming.
An Kenwood TK-2180 would be ideal and KPG-89 software is easy to use and cables can be found online for not much money.
Trucker700
Driving a big rig I drove along miles of railroad tracks and have been in and out of rail yards as well. I never felt the need to get up close and personal with trains and their crews. I was able to hear plenty of chatter from a safe distance that way. So, I never took my scanner out of my truck and walked around railroad property with it.
James
