Hardware for Programming XTS 3000
Radiocar
Salty Coxswain
Los Angeles County, California
TL;DR - Any Laptop recommendations for programming a Moto XTS3000 UHF?
I have had my radio for a little over six months now and during those first four I had a lot success with using CPS. I purchased a good FTDI Ribless programming cable with the included Adapter and it worked wonders. Undoubtedly A month or so ago I encountered an issue with one of my OSs while tri-booting linux, SP3, and windows ten. Ever since that incident I would always receive “failure to read” errors no matter what virtual ports I used, cable I use, or radio I use, or even if I’m using a serial port card on PCI slot. Now i'm pretty much fed up with my tower and are looking alternatives. I would prefer a laptop with XP SP3 pre installed, and has a serial port. My budget is $100 shipped and will accept any and all of your wise and experienced recommendations from a Toughbook to a Dell.
Thanks all.
ElroyJetson
Dell Latitude D620, D630, D820, or D830 are four options you should be looking for.
They're very reliable, common, cheap (these days), and a first rate choice for dedicated radio programming. In the event of a rare problem, they're easy to work on and getting spares from
used units is dead simple and dirt cheap.
Run them off a small (40 or 80 GB is PLENTY) SSD and don't burden them with anything but
radio programming software. Keep it simple.
No dual/triple boot nonsense, either. Pick one OS that works and stick with it on that laptop.
Radiocar
Salty Coxswain
Thank you sir. There exactly what I'm looking. Common, reliable and especially cheap. Hopefully I can finally update those CTCSS tones for my crew's RP.
Project25_MASTR
TX-COMU
Texas
32 bit versions of Windows XP and Windows 7 will handle the Astro Saber CPS without an issue. Though you can get away with using a USB to Serial adapter (I've never had an issue with this route on my Mac Book Pro) it is always best to use straight serial. I've got an old CF-27 at home that I keep as a anything XP backup programmer.
