Thanks, guys. CapStar, my computer has both Vista 32 bit and 7 64 bit. I'll probably get the free upgrade to 10. Which should I choose from the driver & tools drop-down box? If I install a faster processor, and I should upgrade the BIOS, but don't, what will happen?
you would have a non-booting system as the board with the invalid CPU microcode trying to boot it.
the microcode contains the data for the board to even access the CPU at certain pins on the POST Test.
POST - Power On Self-Test
without a POST completing due to the fact the board cannot even correctly boot the CPU much less get BIOS to see the CPU. you have exactly that, a dead system.
your best bet is to VERIFY the CPU is listed on the link i gave you and verify its listed as compatible with the latest BIOS Firmware image.
OR!! you can do Quest's suggestion. a new CPU/Board/RAM setup.
the OS has NOTHING To do with whether a system will even enter the POST phase. POST test is pre-OS boot periods and is STRICTLY hardware with no drivers of any kind. these are hard written ROM instructions that you have no access too.
one curious question.... how are you booting Vista x32 and 7 x64 independently?
only if you run them on two separate partitions or completely different drives could you achieve that. and i hope you have more than 4GB of RAM for that x64 OS.
no problem. if it already meets the minimums, are you just looking for more horsepower?
if yes, a simple CPU upgrade is only part of the equation. being that is a DDR2 board with the max spec'ed DDR2 of 1066, you would be okay, but DDR3 or DDR4 ( for that matter which is becoming main stream now) , would give you much better results.
its your choice of course, but i would do Quest's part ( for once ) Board/CPU/RAM
just for the long haul term of staying free of upgrades.
why do you retain vista? may i ask?
Vista is even still to do this day plagued with bugs that 7 Solved. after SP2 for Vista they actually removed many features of the Initial RTM of Vista.
no need to answer if you dont want to, im simply curious. i don't even support Vista on customer's systems anymore unless they specifically deny a conversion to 7.
Why don't you just up grade the whole mother board and cpu chip,just make sure the form factor is the same,good luck..........
UTX?
UTX is 4.4x4.6 not 9.6x8.2
9.6x8.2 is Micro ATX. not UTX
microATX (sometimes referred to as µATX, mATX or uATX) is a standard for motherboards that was introduced in December 1997. The maximum size of a microATX motherboard is 9.6 × 9.6 in (244 × 244 mm), but some microATX boards can be as small as 6.75 × 6.75 in (171.45 × 171.45 mm). The standard ATX size is 25% longer, at 12 × 9.6 in (305 × 244 mm).
