Hello all,
I am having difficulty programming a second system in to my Harris P7300.I successfully programmed P25 Phase 1 800mhz Baltimore FD and PD and everything works great.I attempted to add the county end and it is also a P25 Phase 1 800 mhz.
Radio scans the county side but does not pick up anything.I did notice in the frequency settings on the county side the OSC SHIFT IS CHECKED and greyed out.On the city end it is not checked and it works fine. Could this be the problem? If so, how do I uncheck the OSC SHIFT on the county side? If not what else should I check? Thanks
