Harris Unity XG 100P encryption question
Gadgetmann
Ingham County, MI
My 100P has DES encryption only but I am told when that feature was put in the radio it was a DES/AES 256 package deal. Meaning it should also have AES 256. Anyone have any information on that?
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
I am aware the radio does not have AES but to add it does it just need a new feature string with that feature or is it a hardware module that needs to be added?
If under features you saw it only say 'Encryption' as one word and nothing mentioning 'single key' then yes you have AES and DES capability and just need to load the AES firmware module to use it.
Gadgetmann
Ingham County, MI
Ok and yes it only says Encryption and nothing mentioning single key. I will follow up more with Harris' TAC, thanks.
Gadgetmann
Ingham County, MI
Is a feature string for a radio specific and matched to an ESN of a radio?
Does a feature string for a Demo/dealer radio have all features/options in it?
prcguy
So is this AES module the same as a DSP file? I recall long ago upgrading a P7100 to encryption, I need a DSP file before loading encryption keys.
There is a separate ess file for AES and DES. If you have a feature that allows AES and you don't show an "AES Version" in the programming window when you read a radio then installing it should give the radio AES. The version I use is HALM_Non FIPS_R05A01.ess.
