HARRIS XG-75 PROGRAMMING ASSISTANCE
N195HM
Looking for someone to assist in loading my portable unit. Just needs local talkgroups of which I can provide.
AF1UD
Little off topic. Any idea where I can get a programming cable for these units? It's my understanding that it's not the same as the 100 or 200.
TDR-94
The XG-75P/25P/15P all use the same programming cable. It's a serial cable with a TTL converter. The XG-100P and XL portables use a direct USB connection and a completely different connector type.
NLT has them. You have to pay to play in the L3HARRIS sandbox!
n3obl
Ø
PA
On a side topic I have a xg75 that just had 39 added and was a former open sky radio. However under sysgrp is says 0 and unable to select trunking groups on the radio. Keep saying invalid sys. Any suggestions?
ElroyJetson
If someone hacked that 1500 dollar P25 Phase 1 feature into your radio, that same person will have to hack the 250 dollar Phase 2 feature into your radio, as Harris won't touch a radio with a feature string that doesn't match their records, except to give you the string(s) that match their records.
N195HM
Sheriff and other county departments are P25 Phase 1 trunked. Does your radio have option 39, P25 trunking in it, for starters?
It sure does. Radio was accidentally wiped by another person. Had most counties loaded into the radio. Previous tech that programmed the unit moved away.
wanabe
If you get phase 2 option, feature #47, you can also listen to Clearwater PD West/East dispatch. The rest of the CPD channels are encrypted.
Fowler
FL
I've picked up an XG 75P with P25 trunking and Phase 2. Using RPM 10d I got the dreaded Err 510 radio programmed with newer software. I'm a little rusty on the firmware downgrading...anyone point me in the right direction and what firmware would I need..R02A26?
TIA
prcguy
If you read and save the original encrypted feature string you can stick it back in if you need to send the radio into Harris. But why would you do that with such an old radio?
wanabe
Not the Car-Car talkgroups
Im not sure that’s right. The car to car groups are encrypted. The only channels that are open are the dispatch channels…ie: west, east, beach. And maybe a Harris super patch of some sort. I’ve been listening to CPD since the 1970’s when they had GE uhf radios and 2 or 3 channels.
