having issue with bcd996xt
buddd
cincy ohio
hello im having a issue with a bcd996xt and was wondering if anyone could answer a question for me
i have a channel that i can not hear anything on,like its scrambled,i get all p-25 just fine,but 1 channel i programmed in,and it shows the nac is 293 but i can never hear anything,it sounds scrambled
the freq is 460.4250,its a old cincy pd freq before they went to trunking,someone now using it,and i would like to hear whats going on,as it may be a news channel or something
how come it receives every p-25 channel but this one,and or how can i get this channel ??
thanks in advance
sjlamb
Sarasota County, FL
thanks in advance
Maybe it IS scrambled. Not uncommon at all.
buddd
cincy ohio
if it unscrambles all the other channels how come it wont just the 1 channel,it shows the nac being used so i figured it would unscramble it auto ?
SkipSanders
Silent Key
The only licensee in Ohio for 460.425 is the City of Cincinnati, so that's most likely who is using it.
Quite possibly one of their 'detective' type groups is using it encrypted, and perhaps simplex.
SkipSanders
Silent Key
Buddd, 'decode' is not the same as 'decrypt'.
P25 is digitally encoded. Said digitally encoded signal may then be encrypted, which makes it impossible to listen to unless you have a suitable decryption module, and the decryption key.
Decrypting the signal, if it is encrypted, would be illegal anyway, unless you have permission from the licensee, and if you did, they'd have given you the needed radio.
P25 is a method of digital modulation. Encryption is a way of scrambling the signal so it cannot be monitored by simply decoding the modulation.
The 396T, for instance, would show 'Enc' instead of 'P25' on the display for an encrypted signal.
buddd
cincy ohio
thanks for clearing that up,its a bcd996xt and it says enc when they talk,i wasnt sure as it was a public frequency,but im sure your right,thanks again,it was wierd as i hear all other " private detective " channels but that 1,thanks again
sjlamb
Sarasota County, FL
That 'ENC' that you're seeing is your confirmation that this freq. is being encrypted (scrambled). As already noted; entirely protected from being monitored by ANY scanner. The fact that you hear other detective channels simply is due to the fact that they have been kind enough not to encrypt them.
