Having Issues TX, but can RX
tadpole207
NC/SC
Hello
I am trying to transmit on 462.650. According to the web, there is no CTCSS codes needed, however when I try to transmit, I get no response.
Can you help me figure out why no one can hear me?
With Freq’s that have no step and CTCSS tones or DCS tones, what could the issue be I have my license, (I’m new) and can’t figure out why people on the net don’t hear me or answer. I am in US-South Carolina.
thanks
Nick
dcr_inc
Not an EXPERT !!
Delta, Pa
Horry County 462.550 and 462.650 are both 77.0 Hz pl according to the database... If you click on the frequency, left column, it will open up the details for the repeater.
tadpole207
NC/SC
Thanks. Horry is offline, the correct one is:
Rock Hill, SC
WRMI622
GMRS Repeater ID: 45-307
Downlink:462.650
Uplink:467.650
according to mygmrs, see image attached)
B2WR 650
Name
Rock Hill, SC
WRMI 622
DJT3RBO
Owner
REQUEST ACCESS
Open System
462.650 MHz
Frequency
141.3 Hz
Input Tone
141.3 Hz
Output Tone
Online
34.8 Miles
Range (Estimate)
a month ago
Last Updated
So i set CTCss code for 141.3, did a test and got no response. Any other settings i need to change on the radio?
thanks so much
n
  • B2WR 650: Rock Hill, SC - myGMRS.com 2022-03-22 09-47-58.png
vagrant
ker-muhj-uhn
California
On "Open" systems use the 141.3 CTCSS tone when you TX to open the repeater. This (141.3) is also referred to as the travel tone. Not all "open" repeaters use that tone, but it is typically used. A further look on mygmrs.com notes that the WRMI622 repeater does use the 141.3 PL tone.
Additionally that page notes: "Update: The repeater is live with limited RX/TX due to the fact that we are waiting for our antenna and tower assaignment. Please note specifications may change as we get closer to a launch date."
Perhaps avoid using Repeaterbook and use mygrms.com. Sign up for an account and have fun.
Okay, you posted just before I did, but did you enter in the CTCSS 141.3 tone for TX or RX? Even if you did enter 141.3 for TX, did you configure the radio to actually send the tone?
Also, just because you can hear (RX) a repeater does not mean you can reach it (TX). The repeater may use 50W where you are using less.
dcr_inc
Not an EXPERT !!
Delta, Pa
N. Myrle 179.9
Rock Hill 141.3
York 141.3
Sumter 141.3
Toumey 141.3
Edgefield 123.0
Dillon D125
Chester 136.5
You state " So I set CTCss code for 141.3, did a test and got no response. Any other settings i need to change on the radio? "
Do you mean no repeater tail when you let off the PTT ? or just no one answers your call?
tadpole207
NC/SC
@dcr_inc Do you mean no repeater tail when you let off the PTT-
A. yes, no tail. I have CTCSS set for 141.3. I tried this on 462.600 MHz as well. same. Do i need to set + or - in signal direction? https://mygmrs.com/repeater/1156
@vagrant Okay, you posted just before I did, but did you enter in the CTCSS 141.3 tone for TX or RX? Even if you did enter 141.3 for TX, did you configure the radio to actually send the tone?
A. As fas i know, all i was supposed to do is set the TX CTCSS to 141.3- but i wondered if i am missing a step like the signal direction or offset?
Am i missing something so simple, i just keep overlooking it?
thanks to you both, very much.
Hit_Factor
Saint Joseph, MI
Here is an example of a repeater that's local to me. This particular repeater uses DCS, the one you want is CTCSS.
mcjones2013
Radio Communications Enthusiast
Sacramento, CA
From what I'm gathering, it seems OP might be talking on the 462 outputs/simplex and not the 467 repeater inputs.
tadpole207
NC/SC
thanks. This is what i got sent back from the owner
lease feel free to use the repeater. Make sure you gave your radio set to transmit on the correct frequency and PL Tone. The transmit frequency is 5 Mhz higher than receive. should be a setting in the radio to set the TX offset to +5 mhz.
Going to try offset to +5 and will report back.
tadpole207
NC/SC
so far, this is what i have set:
462.600
rx: 141.3
tx:141.3
offset +5
still cannot get return
462.650
rx:141.3
tx:141.3
+5 offset
cannot get tail.
I am a newbie to HAM and GMRS, have experience in satcom in military- i might be confusing myself so your patience is appreciated. I really want to get this right.
thanks
n
ecps92
Taxachusetts
set up a time with the repeater owner, to try over the air.
No Tail can be multiple issues, such as you are not close enough to open the repeater, or the tail is so short your radio won't hear it on a ker-chunk
462.600
rx: 141.3
tx:141.3
offset +5
462.650
rx:141.3
tx:141.3
+5 offset
cannot get tail.
thanks
n
vagrant
ker-muhj-uhn
California
Read up on your radio manual and ensure it is set to TX the 141.3 tone. Again, you need to set the tone…and ensure the radio is transmitting it. Just because the tone is setup, does not mean it is transmitting it. Also, as previously noted you may be too far away and or do not have enough power.
jeepsandradios
East of the Mississippi
Where are you in relation to the repeater ? Many folks think repeaters cover large areas. Most do not. Get close to the repeater to start.
Also this repeater is on MyGMRS
Note text at the repeater listing - " Update: The repeater is live with limited RX/TX due to the fact that we are waiting for our antenna and tower assaignment. Please note specifications may change as we get closer to a launch date. Repeater sponsered by www.Buy2wayradios.com "
Sounds to me like it may be a repeater issue and not your programming also.
chief21
Western NC (Summer); Tampa Bay FL (Winter)
set RX frequency to 462.650
set TX frequency to 467.650 (this is the necessary +5 MHz offset)
set TX tone to 141.3 Hz
no need for any RX tone
If this doesn't work, you may be too far away to access this repeater.
tadpole207
NC/SC
Thank you all. @chief21 if I set offset as +5, doesn’t that automagically change my Tx freq? Should I rely on that or should I set my tx freq? Does it matter which way you do it? Thx
jwt873
Woodlands, Manitoba
The auto offset should change the frequency for you on TX. But, as chief21 points out, there isn't a need to set an RX tone.
Note that some repeaters don't pass on, or transmit a tone, If the one you're trying to access doesn't transmit a tone, then you won't be able to hear it with the 141.3 receive tone set on your radio. Turn it off and see what happens.
Hit_Factor
Saint Joseph, MI
If the OP could post a screen shot (similar to what I did earlier in this thread), we could answer with what's right and what needs to be changed.
Also, knowing what radio you are using would help tremendously.
