having trouble with wildcard
frank125
hello i am scanning scanlist 1 . which i have manually put in my tgrp ids in scanlist1, my problem is that i am getting from the wildcard tgrp ids that i have not entered. i do not want these. i only want the tgrp ids that i have manually put in, please help ineed to get the wildcard out so that the scanner will only monitor the tgrp ids that i have put in. i hope this is enough info. thanks for any help. i need step by step info on how to do this. sometimes these electronic gagets are a little to much for us dummies thanks again for the help
DonS
Franktown, CO
The "wildcard" TGRP gives you everything. That's what it's for.
If you don't want "everything", you can either:
a. delete the wildcard TGRP (PGM, arrow-key to WC TGRP, FUNC+CL)
b. lockout the wildcard TGRP (MAN or PGM, arrow-key to WC TGRP, FUNC+L/OUT)
c. move the wildcard TGRP to a different (not-enabled) scan list (PGM, arrow-key to WC TGRP, EDIT, CURR, set the "Scan Lists" item appropriately)
