hello spongella,
Thank you so much for the information that worked very well! However i can t adjust at 1.2 or 1.4 because i think we don t have the same version. I send a picture showing the extio. In this picture i pasted a case, under IFcontrol, with the decimations value i have. It seems it is as a correction value for the sample rate... But when changing both sample rate and decimation i can see now a larger frequency range.
Decimation is a curious word. I did not know the meaning! So i looked on the web: Decimation comes from the antiquity, at this time in the roman army they killed one person of ten in a section of soldiers who refused to fight or to obey!!!
In digital signal processing, downsampling, compression, and decimation are terms associated with the process of resampling in a multi-rate digital signal processing system. Both downsampling and decimation can be synonymous with compression, or they can describe an entire process of bandwidth reduction .
Thank you again.
