Hello all,
Came across an interesting thread of using a indoor/outdoor amplified HDTV antenna on a SDS200. Some with successful results.
I found This HDTV antenna I linked has been successful for someone, and thought for the low cost I would try it.
I just have a couple questions. The specs state the impedance is 75 Ohms. Would this be a concern as typical antennas and coax are at 50 Ohms? That's if I understand that correctly...
The next question is, if anyone could help me out, if I wanted to use a small length of coax to get it a little further, would I need to use a 75 Ohm coax for an extended length? I have a small length of lmr-240uf coax but obviously it's 50 ohms and not sure how that would work, or if at all with the HDTV antenna being 75 ohms.
I think those are the only questions I could think of about trying out a HDTV antenna. Any help on my questions would be greatly appreciated. If anyone has any other advice or such on it, I would greatly appreciate it as well.
Thanks all.
Thanks all.
