Headphone Jack
radio3353
Does the G4 have a headphone jack? If so, is it stereo or mono. I can't tell from any pictures and I don't see any mention in the specs about a headphone jack. Or, is BT the only way to have an earphone? Thanks.
ecarvalho
The only way to plug an audio jack on a G4/5 is if you buy the base charger/amplifier which does have an audio out jack.
krokus
Southeastern Michigan
If you go the BT route, check the other threads here, with details on how the BT has some eccentricities.
Sent via Tapatalk
radio3353
I should have mentioned, I wear hearing aids. That is why I am interested in a headphone jack. BT devices all seem to be in-ear.
Any suggestions for someone in my situation would be appreciated. Thanks.
etihparg
Gilbert, Arizona
Has anyone taken the pager apart and installed a headphone jack? I'm thinking about it, but most likely void the warranty.
krokus
It will certainly void your warranty, as well as negate any water resistance ratings.
My guess: there is no reasonable place to install a jack.
Sent using Tapatalk
lsh1885
Orlando, Florida
I bought the amplifier specifically for the audio jack as I wanted to use a recorder with the G4. The audio quality was so much better than the Bluetooth it wasn't even comparable.
