SDS100/SDS200: Headphone Jack
DSC45
Central Jersey
Looked in the manual can't find the answer.
Headphone jack, Mono or stereo?
IAmSixNine
Dallas, TX
Going to go out on a limb. Mono.
Nobody transmitting on 2 way radios is using stereo.
EDIT: boy was i wrong. LOL
UPMan
In Memoriam
Arlington, TX
Jack is stereo (but both sides are being fed the same signal). Do not plug in a mono jack, it will short out 1/2 the output amplifier.
GTR8000
NY/NJ Database Guy
BEE00
KK4JUG
GA
That's good to know.
noaim
Milwaukee, WI
how can you tell if the jack is mono? I mean the speakers I am using are uniden bearcat speakers and the only other place I plug it into is the car aux jack.
I am assuming most now are stereo?
UPMan
In Memoriam
Arlington, TX
A stereo jack has three separate metal areas (tip, ring, base). A mono jack has two separate metal areas (tip, base).
Normal earbuds for pocket radios have a stereo jack. Should look like that.
noaim
Milwaukee, WI
Thanks I appreciate it
SlimPikins
Moses Lake, WA
Is this different from the 436? I have a Bluetooth transmitter and speaker that works on my 436 but not on my SDS.
UPMan
In Memoriam
Arlington, TX
No. However, anything plugged into the headphone jack on any of our scanners need to have an impedance of 4-32 Ohms to reliably operate. Some BT adapters, NC headsets, etc, have impedance as high as 1k Ohm and won't work (or won't consistently work across devices).
rcool101
Eastern Ohio
Mine does. Works on both. Make sure the volume is up on the SDS100. Check with a wired connection
