heathkit vf 7401
VA3JWO
Madoc, Ontario
hi guys... i hope i've picked the right topic to put this question under in the forum ...my friend gave me an old ham 2m radio he found in his old pile of stuff.. he had no use for it.. so he gave it to me.. the radio is a heathkit vf-7401.. the problem is when i turn it on, im immediatly lost... i have 3 numbers on the screen and static coming through the speaker... can anybody tell me how i would go about using this radio??? what do the three numbers mean??? i know the frequency range is in the 143 to 148 range..but does anybody know how to use it or have a manual in pdf form to send me???
any help would be much appreciated.
will
K9WG
Greenfield, Indiana USA
The three numbers are the frequency assuming 146Mhz. That is to say if the digits read 6.52 the frequency is 146.52. Most 2-meter radios of that era only covered the 146Mhz part of the band. Some would cover 146 and 147.
Token
It has been a few years since I used a VF-7401, but let me see if I can help you with the basic functionality. Working from memory here, so if someone speaks up with the actual manual or with a unit in front of them you might want to go with their information over mine.
The 7401 was a very early synthesized 2M rig from Heath, if I remember right only their 2nd or 3rd such radio. And it was pretty limited, as were all synth rigs of the day.
First, the three digits on the front display. They are the ones MHz place and the 100's and 10's kHz place. The hundreds and tens MHz and the 1's kHz are not shown. So, if you see "6.52" on the display you are tuned to 146.520 MHz, unless the "0 kHz / 5 kHz" button in the upper right is depressed, then you are tuned to 146.525 MHz.
The basic synthesizer steps in 10 kHz steps, so the radio can tune 146.520, 146.530, 146.540 etc, etc. To get the "between" freqs ending in 5 you use the "0 kHz / +5 kHz" button in the upper right corner.
The three tuning numbers in the display (the "6.52" in my example above) are changed and selected via the little push buttons under each digit. The two buttons on the lower right side "Man / Scan" and "Lock / Latch" will impact how you tune or if you can tune the radio.
The rest of it is pretty basic, the Volume and Squelch knobs should be self explanatory. The "Mode" knob will select if you are in simplex or repeater mode, and the offset of + and - 600 kHz for repeater mode should be displayed as the switch selections.
T!
