Help again
minasha
NYC
My pro-95 has discriminator output feeding my audio in on the computer soundcard.
I run DSD plus all I want to see is DMR channels info Color Codes, Slot and TG's I land on a DMR channel and I don't get any of this info
What am I doing wrong?
Ubbe
Stockholm, Sweden
Try using the dsdtune.exe program to get all the parameters to their optimum values. If that doesn't work then it might be the discriminator tap that are too bad with too low quality of the audio signal. You can probably tap the R key on your keybord to start to record a raw audio file and then tap R again to stop record. Zip that file and post here so we can try your audio with known good setups of DSD plus. Don't record more than 5 sec or the file would probably be to big to post here in the forum.
/Ubbe
