Well guys I got home from work thought I would play a bit before bed. I Edit the FMPP.cfg with the serial number from my SDRPlay and then run FMPP-CC.bat and 1R.bat. Click the spectrum window and typed in 153.755 My local PD on a conventional P25 freq and it worked! So Then I thought I will try DMR real quick and put in 446.500 which is my hotspot I'm a ham radio OP and that did not work. Would not decode DMR. I will have to try it on some local business during the day before work. I have not tried and trunking P25 yet like MOSWIN in Missouri. Looks like I still got alot to learn about this DSDPlus and I don't know why I have plenty of scanners that does all this but I like to learn new things. Thank you guys for getting me started in the right direction.
That is good news starting out. Whatever you, do NOT get click-happy in the menu system and do not start changing values because you could not get your hotspot traffic to decode. First off, your hotspot is right next to you. There was probably way too much gain. You should turn the gain all the way down on the SDRP if you are going to try to monitor a transmission 5 feet away from you.
Try actual signals around your area - P25, NXDN, DMR, Fusion, D-Star, whatever -- just don't think there is something wrong because it's not decoding your hotspot.
If you have a local P25 trunked site, find it's current control channel, type it into FMPP, and make sure there is enough gain set but not too much. It's going to start decoding that site. Worry about your hotspot last, and understand that no setting (default setting) when you installed it will not miraculousliy allow you to suddenly pull in your hotspot. If you can't pick up the hotspot, it's probably wiping out the frontend of the SDRP.
