Help finding a Multi-band Low Profile Antenna
kb1fua
Stover MO
That's what I'm running (post #2 above) and they work fine. Sounds like the agency wants something lower profile than that.
I ran it on the work truck for a while, swapped it out with the EM Wave version. I put the Larsen on my personal truck since it's thinner and blends in better.
I used that antenna for the scanner, until I got the actual scanner antenna (MFJ discone). It does hear better!
The Larsen performed well, just stuck up on the steel roof on the magmount, but I got the scanner antenna up about 8' higher, and I can hear the Jeff City ham repeater now.
Skypilot007
Medford, NJ
For fully marked cars the compromise antennae do not make any sense at all other than convenience at the car wash. Unmarked cars, yeah I get it, but for fully marked I'd be putting the best performing antenna I can find on there regardless of its size. Down the road after the puck antennae are performing poorly they come back complaining and its all your fault.
BigLebowski
Piedmont NC
The best you are going to get for "low profile" is either a Sti-Co flexi-whip multiband, or, my recommendation would be to use the APX8500 triplexer and break it out to a sharkfin for UHF and 800, and a Sti-Co flexi-whip for VHF.
WB5UOM
I think you said you needed V/U/800
so then:
STI-CO®
Stealth Permanent Mount - Triband kit with dual band CPMT for V/U and CCAS patch antenna for 7-800​
APX8000
Sarcastic Member
AES-256 secured
The above one uses a patch antenna on the window for 7/800. This one is what we use which is the sharkfin with tri-band whip:
STI-CO Industries, Inc.
VHF / UHF / 700 - 800 Covert Universal OEM Shark Fin Antenna with Flexi-Whip™
AF1UD
A little late to the party, what would you use for a triplexer to combine all 3 antennas to 1 radio?
rgchristy
Delco, PA
I just received an email from Arcadian today.
The price range is $145 to $180.
I know that you said that you were looking for Laird, but the email said in-stock, same day shipping, since you mentioned that you had one, but the lead time was long.
Interesting antenna. Not impressive performance, but if VHF isn't important, it might be a good solution for some.
With only one feedline, I'm baffled by the decision to use 7/8" hole mounting. While fine for new installs, it's a royal pain in the butt to replace an NMO mount with one of those.
jeepsandradios
East of the Mississippi
I noticed the hole size also. My gut tells me there will be another model using the same case ? I have a few tri band for LTE and stuff that has 3 cables dropped from it.
With that said I plan to order on to try. For 90% of my comms on VHF its car-car or repeaters. Car-car operations are normally in front of or behind the user. May be ideal for that situation. If I can get an antenna on a vehicle vs a portable in the cup holder it may be a sell for a few co workers as well.
rgchristy
Delco, PA
I didn't know if it is the same antenna that the OP found, since it says "new RFMAX Public Safety collection", but I thought that it was worth posting.
Sorry, I just re-read the original post. The OP said that he found one, not had one. At least it looks like there is no lead time on this one.
