Sentinel: Help: Just two channels on a P25 Phase II System
darknetone
I am requesting some help with two channels on a P25 Phase II System.
I am attempting to put the two Culpepper Channels (below) into my SDS100 without dumping all of STARS into the scanner. I made a new profile to play with just this specific scenario. Anyway if I just dump The two Culpepper (below) channels into the scanner I get a "Nothing to Scan" message. If I dump the whole stars tree into the scanner things appear good, but the scanner spends a lot of time rolling through everything else in the list. If I drop avoids on everything except the two Culpepper Channels then I am back to "Nothing to Scan". Any suggestions would be appreciated. Thanks.
dave3825
Suffolk County NY
Sounds like you might be avoiding all of the sites.
Either program only what’s wanted and scan in id scan mode or download the whole system and delete or avoid anything not wanted.
darknetone
I already tried adding the two I wanted to a favorites list, turned on the list etc,... no dice, I also tried adding then deleting what I didn't want and I have also tried avoiding what I didn't want.
If I just add the two Culpepper channels I suspect I have to have a control channel which I thought I had found, but no, I guess not. So I am still stumped,...
darknetone
Hmm Ok so it looks like those "Channels" are talk groups,... so how to I deal with talk groups, I am not a Trunking/P25 guy,...
darknetone
I have the service type covered, etc, all of my other stuff works as I want it to. I just want to trim the STARS stuff down to VSP Division 2 which are the two talk groups Culpepper 1 and 2. I added two sites Arlington and Fairfax what looks like other default sites (I could be wrong). we are scanning but I an still nothing from Division 2 is coming through.
dave3825
Suffolk County NY
So you either deleted all talk groups (departments) or all the sites (sets of freqs from different locations).
Culpepper 1 and 2 are in the department called Virginia State police. So you need that department (group)(of talk groups) and one site within range of you to be programmed in and not set to avoid.
nessnet
Eastside of Lake WA
Wouldn't location control take care of this?
(Only scan the nearest sites/control channels and ignore the others....)?
If you turn location control on, manually set your lat/long, set your range to a reasonably low number, this should limit the sites you scan...
dave3825
Suffolk County NY
Normally, for sites, yes. Not sure how accurate any of the site data is as most of the sites all have a 30 mile range. I have not seen that before.
Interestingly, in the database, the departments all have a range of 0, and no lat / lon data.
But in Sentinel, the departments all have the statewide range of 238 and gps info.
nessnet
Eastside of Lake WA
First - important to remember that - especially with simulcast 'sites' (actually multiple towers), the lat/long is for the geographic center. Same goes for most dept's lat/long. Then, the circle is drawn to cover the lot....
Notice that the circle box is a drop down...?
There are tools on the Internet to create "bounding boxes" - a rectangle, or multiple rectangles that can very accurately represent the actual state/county/city/rez borders. With a GPS - and enough programming work, (range=0 BTW), you can actually have the radio switch favorite(s) as you are entering a leaving one and entering a new jurisdiction.
darknetone
wtp
Port Charlotte FL
culpeper has no towers for STARS, so, do you have all of the surrounding counties in ?
GordonsvilleOrange159.180c159.345161.875c162.000
Fork MountainMadison151.0475151.2125151.280151.3025151.3775151.4075152.0825c
152.7125c161.950
Hogback MountainRappahannock151.3625c151.3925c159.0075159.1275159.3825161.850161.8875
161.900
ThornburgSpotsylvania151.1825151.430152.0975c152.8025159.2025159.3975c
and i guess you can hear something as you waid yo locked out some.
but the two you want to hear have to be on the radio for you to hear them.
darknetone
152.7125c161.950
161.900
Sorry I meant Culpepper Talk groups 17 and 19 I really am not worried about the talk groups, I think I just need to "whittle does the sites" and leave everything else along and I should be OK, my end goal was to reduce the number of "extra" sites being scanned. I probably could have just set a "range" on a STARS favorite list and been done with it.
  • Like
Reactions: wtp
nessnet
Eastside of Lake WA
Location control is your friend.....
tkenny53
socal
One thing I learned with trunking is on the Site, let the scanner scan with a full database of the dept you want. Watch the top of the screen, it will display the word DATA while is is scanning, make a note of which site shows Data, yeah it may put you to sleep, but it will allow you to see which site you can receive. then just remove the sites that dont work.
