BCD325P2/BCD996P2: Help me with programming
ptl117pb
Northern New Jersey
I need help programming my 996p2 truck Tracker V
I was able to program most stuff into scanner using Pro scan and RR account. I tried to program
New Jersey Interoperability Communications System (NJICS) Essex County into the scanner and it doesn't show up. What did I do wrong?​
wtp
Port Charlotte FL
is it scrolling "ID SCAN" or "ID SEARCH" ?
also i see essex njics is simulcast and that is more problems.
sorry, on a re-read i see does not show up, did you set up a quick key ?
hiegtx
Dallas, TX
Since you programmed via software, post your programming file. To attach it to post, you may have to zip (compress) the file in order to post to the forum. You can zip a file using File Explorer in Windows. (ProScan files for your scanner type would be *.txt files, which do not have to be zipped in order to attach to a post.)
ptl117pb
Northern New Jersey
Thank You Steve. Going to post that file when I get home at 2pm today. I did try last night to manually program the system in and I assigned a quick key and I seen it in the scan but nothing came out all night. Thanks again for your help Steve.
This is a steep upgrade from my Home Patrol 2 which is plug and play.
