troymail
Silent Key
I'm looking for some input on troubleshooting a new data slicer
that I built and it's use with trunker.
First - I built a data slicer according to:
http://www.bookshock.com/articles/slicer/intro.html
I believe I followed everything as listed with two exceptions:
I was given an NTE778A in place of the MC4558
I used a DB-9 instead of a DB-25.
I've confirmed a tap (assume it is good) from my BC-245 (I
have audio from my tap lines out of the scanner)
I connected everything up and tried using slicer.exe to
test the setup. However, I'm getting nothing. I've tried
different ports and computers from DOS5.0 on a Dell 266,
to Win2K on an old PC, to WinXP on a Celeron machine.
None of them seem to see anything from the slicer.
Other than the obvious that my data slicer build was bad
or one of the components are bad, any other ideas?
I've read on the slicer.exe doc page that some serial ports
are using 5v verses 12v which could be a problem... can
someone point out how to check that?
Any help would be appreciated.
