Help Programing Fl. Indian River County
etuck
I'm new at this hobby, and have a Uniden sds200 Scanner Radio. Someone helped with programming for another city/state awhile back. I have since relocated to Vero Beach Fl. Indian River County, and was hoping to get some help with programming fire, medic, law frequencies using the Sentinel Software that I already have installed and updated on my PC. Any help with this would be very much appreciated. Thanks!
etuck
I have Indian river setup in sentinel for my sds100. I can send it to you if you want. Sheriff is encrypted but fire is not.
I had to stop my time on attempting to program my SDS200, but hoping to get back with it to learn more now. I have IR County loaded but still not sure I have all options available.
One Question, when listening to the SDS200, I get current fire/medic transmissions only, but online streaming with Broadcastify at the same time, I get Sheriff/Police transmissions at an exact 1 hr. delay, so why are these transmissions not the same on the SDS radio only?? Thanks!
n3obl
ØAES-1024
PA
The police transmission are encrypted if using a scanner. They (the county) is providing an official feed with a one hour delay which is permitted under the terms of service.
They are not going to change anything cause you want them to.
etuck
PBGVOLFF said (" the feed is ran by IRCSO so they can set it up to stream with the delay" )
So, I know about police encryption and delay, so I would like it to stream in my scanner so I can listen to all audio transmissions thru my sds200 scanner without being online at all. How to proceed if so, is what I was asking.?
n3obl
ØAES-1024
PA
You can not run a stream through the scanner!
You would need a internet device to stream with. Streaming and using your scanner is two completely different reception methods. Using your scanner you are listening to the actual radio signals. Streaming in this case is probably a connection off their console system or backend in the comms center.
etuck
OK, Thank you for the info, just learning things for a hobby!
