BCD325P2/BCD996P2: Help programing Uniden BCD996P2
bloodbath814
Poca
i have installed what i need upload it too me scanner and nothing i do not even pick up digital or phase one phase 2 i am using freescan went to my state county installed it to my scanner nothing
hiegtx
Dallas, TX
Please provide a link to the database for the system(s) you are trying to monitor. Also, please post your (FreeSCAN) programming file. You will need to compress (zip) the file in order to attach it to a post. If you use Windows Explorer, and navigate to the folder on your PC where the file is located, you should be able to <right><click> on the file in order to select "compress" from the pop-up menu.
buddrousa
Is this where you are?
Poca is a town located in Putnam County, West Virginia, United States. It sits at the confluence of the Kanawha River and the Pocatalico River, and its coordinates are approximately 38°27′41″N 81°48′56″W. Poca is part of the Huntington–Ashland metropolitan area and has a ZIP code of 25159
bloodbath814
Poca
YESSSSSSSS
Please attach your FreeSCAN .996 programming file so we can take a look at it. You will need to zip the file to be able to attach it. Click on Attach files and open the zipped file.
hope i sent the files right in the zip folder
  • my new files.zip
  • my new files.zip
  • my new files.zip
tvengr
Well Known Member
Baltimore County, MD
wtp
Port Charlotte FL
Putnam County Agencies are using the WVSIRN P25 Network also.
151.1525WRAC535RM3 RANPut Co LE HurrcnPutnam Co Law Dispatch - Hurricane (patched to SIRN)NXDN48Law Dispatch
151.3925WQKG988RM33 RANPut Co LE CoalMtPutnam Co Law Dispatch - Coal Mtn (patched to SIRN)NXDN48Law Dispatch
151.445WRAA990RM23 RANPut Co LE WinfldPutnam Co Law Dispatch - Winfield (patched to SIRN)NXDN48Law Dispatch
151.4825WRAA990RM13 RANPut Co LE BuffloPutnam Co Law Dispatch - Buffalo (patched to SIRN)NXDN48Law Dispatch
154.815WNAQ432RM023 RANPutnam Co EMSEMS - Dispatch (Patched to WVSIRN)NXDN48EMS Dispatch
155.5575WQEJ547RM033 RANPutnam Co EMS PvEMS - Private (Patched to WVSIRN)NXDN48EMS-Talk
154.085WXJ754RM013 RANPutnam Co EMS 2EMS - Ch. 2 (Patched to WVSIRN)NXDN48EMS-Talk
you might want to get the NXDN upgrade.
tvengr
Well Known Member
I would also include the St Albans site which covers a lot of Putnam County. SIRN currently doesn't show any sites for Putnam County. Technically, the System Type and Site Type should both be P25 Standard (Digital XT). It does work the way it downloads from the database. The ID Mode should be set to ID Scan. In ID Search, you receive every talkgroup on the system. In ID Scan, you receive only the talkgroups programmed. I don't know if Putnum County intends to migrate to SIRN or will continue to use the NXDN frequencies. You may want to click on Report and request that your thread be moved to the West Virginia forum. The members there may have a lot more information.
bloodbath814
Poca
i zip a vid show everyone its not doing nothing for some odd reason i have did what the freescan software told me too im not sure if im doing it wrong or what then sometimes when i upload files it throws a ton of Errors then sometimes it works im pretty good building a computer fig things out but this scanner has got the best of me i fig its plug and play even bought the Premium Subscriber to make it easy on me naw still nothing only thing i pick up is analog
  • my vid.zip
buddrousa
Good morning and welcome to Radio Reference as posted above some of your area uses NXDN that is an addon key and digital format you can buy from my.uniden.com also FREESCAN does not support the NXDN Format so you will need to get PROSCAN or one of the other Programming Softwares and import the above programming into your 996P2.
tvengr
Well Known Member
You should see the control channel frequency where NFM currently shows anytime you are not receiving a transmission. You are not properly decoding the control channel. You have the correct frequencies for the Charleston site. Here is a PDF file which will answer all of your questions about using quick keys. Print it out and save it for your reference.
  • Uniden Scanner Quick Key Instructions DMA.pdf
bloodbath814
Poca
i also do have proscan but i do not know how to use it yet
Enforcer52
Voice Of The Piney Woods
Lake Livingston, TX
As @tvengr stated the St. Albans tower is the closest tower to you so you need to program it in also.
How high are the mountains between you and Charleston? If you are using the factory antenna, you may need an outside antenna because it looks like Poca is in a river valley. St. Albans looks like it has a pretty clear shot to you..
bloodbath814
Poca
how can i add St. Albans i do use the antanna that it came with everyone telling me its like cell service if thats the case my service sucks up here, and well charleston has a lot of action no so much putnam seems everyone around me picks up all i dont im not sure what the heck im doing wrong to be a $500 scanner and then i need to pay a nother $75 just for the MXDN format is silly to me ill just sell it not worth it to me i just wanted to hear local i had no clue i had to go all though this i got the prem acount for here and upload like it says the scanner is like a brick does not pick up nothing
Enforcer52
Lake Livingston, TX
Added St. Albans to your file. Download it, unzip, and load into Freescan, then write to scanner, see if you pickup anything.
Edit: Make sure all the Service Types for Law, Fire, and EMS are turned on.
  • my new files 2.zip
bloodbath814
Poca
gonna sound dumb i am but how to i turn on the Service Types is it the check box Pri
bloodbath814
Poca
this is what its doing pretty much a brick lol
  • another Vid.zip
Enforcer52
Lake Livingston, TX
OK, try this file, see if it loads.
Check your PMs, the envelope top right hand side of screen.
  • my new files 3.zip
