Help understanding Fire dispatch...
KE5HOB
I was listening to the fire dispatch here in houston, 453.425, and heard the following:
Motor Vehicle Incident
Ambulance XX (can't remember the number)
Westheimer Rd. near (unintelligible) Rd.
and then something that sounded like D-patch, possible "dispatch?" 490 Z, Zulu TAC 3.
I understand everything until the end of the location, can anyone decipher that for me?
matthewtomek
Live Audio Admin
Memphis, TN
You may get a better response in the Texas Forum, if you're talking about Houston, TX Fire Department.
KE5HOB
Mods can you please move this to the Texas forum?
You know I didn't think of that. Thanks for the suggestion! I hope the mods read this and move it. In the meantime, anyone got any ideas?
zerg901
yup
They use "Key Maps" in Houston. I think you heard "Key Map 490". Peter Sz
Raven95150
Nowthen, MN
That sounds about right, it's the grid location on their map...in this case it is 490 Z.
"TAC 3" is referring to a radio channel/talkgroup. (in this case tactical channel #3) All units responding to this incident will switch to that channel.
KE5HOB
Wow, now that I listen to it, it DOES sound like "key map" lol. I could not for the life of me figure it out. Are the TAC channels listed on this database? And can someone explain a key map to me please? Sorry I'm such a n00b to scanning.
KC5EIB
Flower Mound, TX
http://www.radioreference.com/apps/db/?aid=15 lists the frequencies of all the Fire/EMS channels.
The Key Map, Fire Box, Grid number, ...... information refers to pages in a map book carried on all equipment. These maps show not only street namers and block ranges but show locations of fire plugs and some hazards.
mfn002
Bryan, Texas
Actually, I know of two counties that use the keymap system: Montgomery and Harris. The area is divided into grids. Each grid square contains smaller grid squares lettered A-N, P-Z (I think). So, when a call is dispatched, the keymap is given as main grid square, then sub-grid square.
Another quick tip about listening to Tac 1...When you hear three beeps, it's a fire call. A Hi-Lo tone is a medical call.
Oh..then there are the "pager" codes.
-111: Rescue Incident
-549: HAZMAT Call
-710: Request for EMS Supervisor
-900: Airport Incident
KE5HOB
You guys are awesome. Thanks for all the information to help make my scanning easier and more enjoyable!
motorola_otaku
Here's another: if you don't want to listen to routine EMS stuff and minor incidents, and get sick of listening to the robot, just scan Tac 7 (462.975) and Tac 8 (460.625). Those are the first and second-assigned channels, respectively, for structure fires, airport incidents, major accidents, gas leaks, major rescue calls, and other "hot incidents." Tac 5 (460.575) is the third-assigned if 7 and 8 are in use, but it's also used for training and doesn't get much working-incident use, so you can skip it if you want.
zerg901
yup
There are lots of letters and words that rhyme in the English language - it makes radio listening tough at times.
A - K - J - bay - say - way - etc
B - C - D - key - E - G - P - T - V - etc
I - Y - sky - lie - pie (mmm, pie) - etc
Peter Sz
