geoffmercer78
I recently bought this scanner. I purchased the 3 licenses Provoice, Dmr and NXDN. I cant get the scanner to pick up hardly any thing. I am new to this so I probably doing something wrong PLease Help someone
Please give us specifics on what exactly you're unable to pick up. Provide Radioreference database links so we can rule out possibilities like encryption, simulcast distortion, etc. Also, how are you programming the scanner, via Sentinel? Entering zip code? The more specifics you give us will help us help youI cant get the scanner to pick up hardly any thing.
I'm not going to attempt to answer your question because there is too little information, but I will give you some food for thought that others will likely ask. 1) How was reception BEFORE you installed the 3 license upgrades? 2) You say your recently bought the scanner... new or used ? 3) How is reception on conventional non-digital frequencies? 4) How about reception in P25 mode? 5) Have you had experience with other scanners? 6) A little bit about your location and your antenna configuration.
Theses are but a few of the questions that will need to be answered before someone can start to diagnose your reception issue, if in fact there is one.
I had to turn down my speakers for thatTo answer your questions
1) I WAS AND AM GETTING GOOD RECEPTION ON THE SCANNER MOST TIME IT IS FULL OR CLOSE TO IT.
2) I BOUGHT THE SCANNER NEW
3) THE RECEPTION IS GOOD ON CONVENTIONAL FREQUENCIES AS WELL JUST NOT PICKING UP MANY OTHER THAN RAILROAD TRASMISSIONS.
4) TO MY KNOWLEDGE I AM NOT PICKING UP P25, OTHER THAN WHEN I RUN THE TRUNKED DISCOVERY MODE AND IT IS PICKING UP 200 HITS IN A 24 HOUR RUN ON THE ALBERTA FIRST RESPONSE RADIO COMMUNICATIOIN SYSTEM UNDER EDMONTON SIMULCAST
5) I ORDERED A WHISTLER RADIO BEFORE THIS ONE AND I HAD IT FOR 3 DAYS AND DIDNT LIKE IT AND RETURNED IT, SO REALLY NO EXPERINCE
6) I HAVE AN OUTDOOR ANTENNA 40 FEET FROM MY HOUSE I AM USING RG-58 COAX CABLE (BNC CONNECTORS) AND SO IS THE SHORT CABLE ON ATTENNA
LIKE I SAID I DONT HAVE ANY EXPERENCE WITH THESE RADIO I THOUGH IT MIGHT BE AS GOOD HOBBY TO GET INTO ALL THE VIDEOS I WATCH MADE IT LOOK SO EASY TO USE. ANY HELP YOU CAN PROVIDE WILL BE GREAT
THANK YOU
GEOFF
@geoffmercer78, what @APX7500X2 means by that is since you responded in ALL CAPS, you were essentially yelling. That is not good netiquette. I just wanted to mention that in case you were not aware of that courtesy.I had to turn down my speakers for that
With respect to the Alberta First Responders' Radio Communication System (AFRRCS), what talkgroups are you specifically trying to listen to? Under the "Mode" column, here is the legend:
D ---> Digital (your scanner can receive these talkgroups)
De ---> Digital with Part-Time Encryption (your scanner can receive these talkgroups when encryption is not being used)
DE ---> Digital with Full-Time Encryption (your scanner and all other scanners will never be able to receive these talkgroups)
The only caveat that I have is that the "Mode" column entries may change at any time without prior notice.
