Help With Scanner Live App
tonya
Bratenahl Ohio
I recently had to purchase a new computer. Its a windows 7 64 bit system. Im trying to load the Scanner Live software with no luck. The sofware starts to load and gets about 3/4 of the way through but I then get this error message-Application cannot be started notify the vendor. Ive tried turing off the firewall with no luck. Any ideas out there?
rdale
Lansing, MI
Sounds like you are installing the 32 bit version. Install the 64 bit.
tonya
Bratenahl Ohio
Thankx for the responce. I did download the 64 bit version but I keep getting the error message the the application cannot start. I also tried to run in compatibility mode. No luck!!
tonya
Bratenahl Ohio
Got it working. It looks like I tried to install this earlier and maybe did the 32 bit version and when I treied again today it maybe was conflicting. I uninstalled both versions and reinsatalled with no problems. This is really a great program here in Cleveland because CPD and CFD and EMS are on a system that no scanner can monitor!!
