DSDPlus Help with setting up LRRP in DSDPlus Fastlane
BM82557
Berkeley Co WV
Ok, my local LE went ENC so I have been looking at other things within my reception range. I found a CAP+ sending out LRRP but am having trouble getting LRRP.exe in DSDPlus to show as centered on my local area, it says Off Map on the title bar. I might have the LRRP config file setup incorrectly but haven't been able to figure out what I have wrong. First screenshot shows DSDPlus and LRRP, second screenshot is my LRRP config file with the 5th line being my latitude and longitude. Anybody see what the problem is? --
BM82557
Berkeley Co WV
I've adjusted the config and got it to work, what is the correct format to be used for the max age?
cg
Connecticut
Infinite is Max
[ / ] adjusts while running.
I have it set for 1 Minute and that is what it says in .cfg file. Try "1 Hour", etc
alabamarailfan
@BM82557
Can you let us know what changes you made to get it working? I have run in to something similar and feel confident that I have my lat/long set correctly but still getting the same black screen when running LRRP.exe
Thank you in advance!
BM82557
Berkeley Co WV
Pressing / in LRRP pulls up the following menu, make your changes using it. In my first post I didn't know it existed and was editing LRRP.cfg manually --
