Help with the 2 dongle + UniTrunker direct mode
nlurker
Also, I am running 64-bit Windows 7. Maybe the 64-bit driver is incomplete?
The program mutes the audio to the digital output when no digital calls are present. Your DSD+ levels should drop to zero between calls.
W2SJW
Senior Member
Northwest NJ
All tests complete - De-emphasis is off, squelch is zero, and parking the voice receiver still gets me no analog audio...
With deemphasis off, you will hear unfiltered discriminator audio.
How does the waveform look on the Oscilloscope tab?
What is your parked frequency?
W2SJW
Senior Member
Northwest NJ
I was parking it on a known NJSP voice channel for the north system - 856.9625.
W2SJW
Senior Member
Northwest NJ
Nada. I even used my UHF portable. I got audio just fine out of the dongle when on SDR#, but nothing when I use your software to directly control the dongle alone.
These are my settings:
Did you try your local NOAA channel?
In New Jersey ... 162.400, 162.450, 162.475, 162.500, 162.550
How does the waveform look on the 'Scope tab?
When you click the Start button, does it stay running?
W2SJW
Senior Member
Northwest NJ
Too far away to hear the NOAA channels. The waveform fluctuates when receiving audio into nice peaks, and then returns to a slight wiggle when idle. The dongle starts with a pregnant pause of about 5 sec, but runs every time.
I was temporarily parked in that picture trying to use one of my own HT's as an audio source...
wildbillx
Cape May, NJ
Hello all, so I finally got a second dongle and need some assistance. After setting both up with ppm and gain and freqs. I cant get both to run at the same time. I also noticed that they both are labeled the same in RTL device. What am I missing?
joeuser
The Wretched
North Central Kansas
Nothing, its the same on mine - you'll notice a difference inside UT when you select them. Save that info.
