help with uv82
i have a baofeng uv-82 radio and it will not let me manualy program noaa frequency. it just beeps when i press mem-ch i think it has somthing todo with the fact that its receiving a signal while i try to program
but noaa allways transmits so how can i program. also will the uv5r usb cable work with uv82.
thanks.
stircrazy
London Ontario
Take the antenna off while you try to program the frequencie.
The cable for the uv5r will work with the uv82. I have both radios and have them set up identical. The 82 works a lot better than the 5r. I use the 5r as a back up only.
