Help with VX2200
burky351
VIC
hello i am in need of some help.
i have a Vertex VX2200-g7-45, the issue is when i turn the radio on it will power up and then the screen will turn off with no response from the radio. it will not power on again unless you turn off the power supply and discharge all voltage to the radio. the strange thing is i can upload and download to the radio useing ce-82 V3.01 and when i do so the screen will power on and come up with PC-Prog. hopeing someone can help thankyou
MBill
That is interesting.
First I would make sure your power supply is adequate for the radio. A 15 amp DC supply would
be good. Make sure you are actually getting 13.8 volts too. I've seem something similar happen
when you are not getting enough amps from your power supply when you transmit.
Also check all the menus in programming maybe something is enabled to shut off the radio or
"lock" it up after turn on, except when you are in program mode.
Otherwise sounds like you may have some sort of internal power problem inside radio such as
a bad voltage regulator, etc.
Bill
burky351
VIC
Thankyou for replying
Funny you mention about the power supply. iv recently had to replace the 4 capasitors in the power supply and vdc is at 13.6 steady, iv used other radios with no issue.im going to look through the software and look at the menu options.
burky351
VIC
So after playing with the software a little more Iv found a option that puts the radio into back up mode when turned on after changing the option it seems to be working. Now I'm just trying to work out how to upload uhf cb frequencies.
