I hope it's okay to ask about wifi antennas?
I am trying to build something for wifi for very small distance but with walls and objects that is weakening the signal
I have the following
9 flat aluminum pieces (14 cm) from old uhf or vhf antenna to be used for directors and reflector
copper tube (14-15 cm) (9mm diameter) (1mm thick) to be used for driven element
and already have 2 dB antenna as coaxial
I am aiming for 2412 GHz since I use channel #1 and with the parts length I have I can do 19 elements
The best/clearest calculator and simplest design I found is this
KN9B - YAGI
But I have no clue about mixing copper and aluminum or using tube for driven and flat for directors.
Maybe put the flat directors on their edge instead of on the flat side?
What do you think of all this?
KN9B - YAGI
