Hi-lo tones
firebell9137
Hi all. is there a way for the G4 to only decode hi-lo tones once so it doesnt keep alerting throughout the tones? it keeps cutting off the beginning of the dispatch after tones as well. Im using Most current firmware and pps.
Have you tried adjusting settings in E-11?
krokus
Southeastern Michigan
What are you calling a hi-lo tone? Is it something played between the two tone and the dispatcher?
krokus
ffexpCP
wizard of odd
Michigan
Use the tone detection option to figure it out. I can confirm the pager will alert with the 2-tone alternating tone from a motorola console. If you want to get fancy, you can also make the pager alert on the evacuation tone sent from subscriber units.
But to answer the original question, I haven't found a way for the pager to alert only once with these. It will trip on every cycle as long as the tone is sent.
