Hiding the Bedroom Shack from the XYL! :-)
Turbo68
East Devonport,Tasmania,Australia
The more Radios u have the better u can use them and this how i set mine up individually Aircraft/Buses/Marine/Security/Shopping Centres/Trams.
Regards Lino.
ALINCO-DJX2000
2 AOR-3000A/AOR-8200MK3
ETON-HF PORTABLE
GRE-PSR500
ICOM-R3/ICOM-R5/ICOM-R20/ICOM-PCR1000/ICOM-PCR1500/ICOM-R2500/ICOM-R9000/ICOM-R9500/ICOM-92AD D-STAR
JRC NRD-545
RADIO SHACK-PRO97
REALISTIC-PRO2035
UNIDEN-246/UNIDEN-396/UNIDEN-780/UNIDEN-996
YAESU-VX7R/YAESU-FT8800R/YAESU-VR500/YAESU-VR5000
af5rn
N. Tex / S. Fla
Okay, I just have to ask this. Why is your shack in the master bedroom? Just seems to me that it would end up limiting the time you could spend there, as well as being a sore spot to the old lady. I can't have a shack or even a computer in my bedroom, or else I never get any sleep. Maybe I'm just more ADD than others though, lol.
Croaker90
corpus christi
why do you need so much bs? (not being offiensive by saying that, its just I don't know what 90% of that stuff is)
Do you have a job using all that stuff?
Croaker.
N1SQB
Somewhere On Earth
Very Nice set up!
Very nice and very well kept. Nothing wrong with what you have or where you have it!. I have my temporary shack in the master bedroom too.( renovating the downstairs). My wife is a Ham and so its no big deal! Keep it up!
Manny
Twister_2
Dauphin County, PA
I have the pro 2050, and I have problems with the antenna at the connecter. It is one of those that you attach to the back and it is loose. Do you have problems?
WouffHong
Jawjuh :)
Shack Update - July 2008
Well, it may never look that good again as it did months ago, but for the record, a BCD996T now lives above the Monitor, the FT100D has been replaced with a Kenwood TS-480SAT - One heckuva nice rig - And both the TMD-700 and the TS480 remote heads now share a nice moveable wood platform.. TS480 Main Body lives in the right-hand cabinet..
Also made a switching matrix to help de-clutter the Cable collection terminuses (termini?) :)
Coupla new Pix attached - Not the best, but gets the idea across. :)
73 es enjoy!
Tom, W4NOV
http://goflight.org
http://scannorthga.com
My shack is located in the Master Bedroom! (Closer to antenna-farm feeds and good ground! :) ), but was pretty spread all over..
So, we compromised, bought a China-import Roll-top desk, and these shack Pictures are here for your enjoyment and possible adoption into YOUR hide-a-shack! :)))
DC Supplies, Wall-Warts and accessories are in the wood cabinet at right of desk.
See if you can spot the one feature that sparked a BUNCH of dialog on another forum. :))
73
Tom, W4NOV
http://w4nov.com
http://rettysnitch.org
http://hams-r.us
http://spacecoastpress.com *
http://postpolio.org *
* (Both have DL'able MN Bridge-collapse Videos and Viewer)
jon_k
Fort Worth, Republic of Texas
About putting the coax in the jar. In a strike I doubt it'd help.
Imagine this, lightning travels 5+ miles to get to the antenna through the air. You think a jar with an open hole on top will stop it?
What's 2-3 feet of jumping out the top of the jar to the rig next to the jar? (With air being so resistive it generates heat and catches your desk on fire.)
I'd say it's safer to keep the coax connected to the radio at all times. That way if lightning strikes it will ground out safely (fire wise) and kill your equipment.
And if everything is grounded properly outside of the house, you'll never have to worry inside anyways because the lightning will enter the ground before choosing coax as the least resistance.
Just my thoughts. I've read about the jar-trick on other forums and people regretted it anyway. It just makes the strike more violent when lightning has to avoid obstacles in the path.
WouffHong
Jawjuh :)
Bs??
Yeah, it's offensive.. At least the BS criticism is from someone who states he has "no idea what 90% of it is"..
Been a ham for over 55 years and worked on Shuttle and Space Station Communications at KSC.
Not BS - unless you mean - Beautiful Stuff.. ;-)
Croaker.
WouffHong
Jawjuh :)
Zap-Jar
No problem - it is well known by most of us that a direct strike will do it's charcoal thing anyway - the Jar HAS helped in nearby strikes with minor flashovers..
That's the only reason it's used - at times when you can't disconnect the outside antenna(s), which IS the best way..
Tom
jon_k
Tom
Glad you know of the consequence. Some people think the jar is the ultimate defense. Little do some people know lightning traveled through air 4+ miles. Air isn't the best conductor. It came all that way just to meet you and your antennas!
If it came such a long way, the resistance of a glass jar certainly can't stop it. Even if the glass was melted around the end of the plug, the lightning won't bother. It wants ground, and the BNC connector around that glass is a crappy ground. No problem for lightning. It'll just pop out through the insulation at the point nearest a ground. The coax runs nearby your radios prior to jar termination and I bet it'd rip through the plastic insulation to jump into the radios ground.
I mean, people have just laid coax on the floor, and lightning jumps out the end to a wall socket brushing against furniture in the path and causing fires. If it does that, a coax plastic insulator 0.5mm thick won't stop it.
Like you said though, if for whatever reason you forget/unable to disconnect the antennas then a jar is a hell of a lot better than just sitting on the floor.
Croaker.
To the guy who said whats up with all the B.S., what's up with that comment? If I had all of that gear in my house, I wouldn't complain. Some people are involved in radio much more than you are. As a result they get joy out of buying new gear. I enjoy buying new stuff, although I don't have near as much redundancy as w4nov. Give it time, and about 10 years and my desk will probably look like his.
It's not BS when its all perfectly functioning stuff! Why throw out old gear?
