High Power W3 CPS Programming Upgrade?
Layed_Back
Santa Paula, CA
I just aquired a Astro Spectra High Power 110w W3 (T04KLH9PW3-AN-UCM) with a HHCH Model# HMN4044C. The problem I having is I cannot read the codeplug with the CPS software, but it can read and write my other High Power 110W W7 radio just fine. When I try to read the radio it comes back with this message:
"The current CPS version cannot support this codeplug as it is not compatible with this release. Please upgrade to the latest CPS version.
Another thing is when I power up the radio it gives an error "08/10" which is the Siren/PA unit is not connected or present, but after that it boots up fine to the main menu. Could this be the problem? I'm not sure.
What is the latest version avaliable for this radio? For I like to install this in my pickup and my dash is limited on space for a regular control.
Model: T99DX+088W_ASTRO
ID Number: T04KLH9PW3-AN-UCM with HHCH Model# HMN4044C.
Flash Code: 580001-000000-0
1 Meg
2.5 Khz
Any help is greatly appreciated!!!
Thanks!!!
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I believe the latest was Astro Mobile R05.03.00.
Once you get the proper version, you can disable the Siren/PA and your 08/10 error will disappear. It's not the cause of your CPS problem.
