prcguy
When your talking VHF or UHF I would agree there is generally no difference in performance between an NMO style antenna on a 5" dia NMO mag mount and a permanent NMO mount in the exact same location. I've done antenna range type testing between the two and have not seen enough difference to favor one over the other.
At lower frequencies like CB, which the OP is having trouble with and especially the lower HF bands, there can be a huge difference in performance between a mag mount and a well grounded permanent mount. At some point in frequency, the mag mount doesn't have enough capacitance to the vehicle body to couple the ground side of the antenna and the coax will become the dominant counterpoise for the antenna.
When that happens ground losses go up, the feedpoint of the antenna will usually go up and antenna efficiency goes down. Not to mention your coax can be hot with RF on transmit and the antenna match will change as you move the coax around.
I've done some other testing where I've taken a 40m HF antenna tuned on a grounded mount, placed it on a mag mount in the same location and the antenna tuning was completely off the charts. I then made a large surface area capacitor from an 8 1/2 X 11" sheet of copper glued to a refrigerator magnet the same size and connected that to the ground side of the mag mount. The antenna then matched and performed almost exactly like it did on the permanent grounded mount in the same location.
So, you can supplement a magnetic mount with additional capacitance to ground where needed and cure a lot of problems and generally improve performance. I'm not sure if this pertains to the OPs problem, as others mentioned having good results with the same antenna. This was more of a rebuttal to MisterLongwire's comment that mag mount antennas "are just as good as roof mounted antennas", which is not always the case and I would be surprised if anyone concurred when discussing an HF mag mount.
prcguy
prcguy
What is all this HATE regarding mag mount antennas? I have a Wilson 5000 and it works fine on my Toyota truck(11 meters). Slight discoloration on the roof is no problem, versus leaks eventually a few years down the line when the gasket putters out, causing rust. Electrically speaking, and you should "know" being in amateur radio, that mag mounts are just as good as a roof mounted antennas. I speak from experience and I am sure there are a lot of others that would concur. In my opinion to each their own, however don't give false information, especially about capacitance, that mag mounts do not work. I operate 40, 10, 11, and 2 meters with a mag mount with various whips having made more contacts than people at the shack.
