HM788 network settings problem in CPS
e0ne199
Hello everyone, currently I am setting up hytera HM788 radio with CPS for data communication. When I go to "network" tab, I see something like this :
If you look at the "Radio's USB Network communication protocol", the drop-down option is greyed out. Is it related with license issue? Or do you know which options in CPS I can use to enable this drop-down? Any help is really appreciated, thx before.
dazey77
I don't even have that option on 3.3.01.004. What are you sending between? If two HM7xx can't you send the data via IP?
ronaldod
The help file says:
This parameter is available only when Accessory Port Communication is set as USB.
RNDIS you can also hack it with BT. Just a litle work if you like programming an app by yourself.
e0ne199
The help file says:
I don't have that USB option as the Accessory Port Communication...will it also affect the bluetooth connection too?
I am looking to send a file between two radios, but the problem is that transmission needs RNDIS to complete (according to articles I found on google)
dazey77
I have had a similar issue to this for OTAP (over the air programming). The PD and MD series can be set to USB and RNDIS but I can't get it to work with HP and HM (although I found one reference suggesting this should be possible).
