HMN4079 Mic question
WX9EMT
Backwater Medic
Frozen tundra
I have two HMN4079C mics and I am wondering if these mics are some how internally grounded for the HUB. When "HUB suspends scan" is enabled the radio continues to scan regardless if the mic is grounded using the clip or not. Or does this function not work with these mics.
LowderK
LEO / Paramedic
Western Oklahoma
I had that same issue and it was a bad mic cable... get a replacement and 100% working... was your Mic new..?
merlin
DN32su
I have 2 of these mic's and wanting to program to suspend scan when off hook. The XTL doesn't seem to see the hang up button but the same radio in a console does. The button has to be grounded to actually scan. Off hook reverts to priority call channel.
If I recall, HUB suspends scan is off on both radios.
clbsquared
Isle of Wight County
You need to ground the HUB (mic clip) for that style of mic. Most other Motorola mics complete the circuit internally when placed on a clip.
WX9EMT
Backwater Medic
Frozen tundra
I have the HUB grounded. The standard mic that this was to replace works for the scan function. I also opened the mic to check to see if it was grounding inside and was unable to find anything making a loop. The springs are isolated and have also tried grounding both the button and the metal behind it with no change. I also have two of these mics and they both act the same but when I use the standard mic I do not have this issue.
