I recently was able to pick up a antenna tower for my house for $100. It's worn, but appears structually stable, and after doing some research, it looks like it's a Rohn. Originally a 50' tower, I would now estimate that it's about 45 feet after being "removed" from it's former home (removed with a torch, it appears).
After doing some internet research, it certainly appears that the most important part of putting this tower up is the base in which it sits. What I am looking for is some idea on the dimensions that I need to follow in order to figure out the HxWxL for the cement base. Also, how much of the tower needs to be actually in the hole?
I am planning on putting this next to the 2.5 story next to my house, so I will be able to secure it to the chimney ... I'd like to avoid having to do guy wires, but will if it's determined to be necessary.
Thanks for ANY advice you all might be able to give!!
