Remember that you can use a Favorites list for one of your other, such as your SDS100, or one of the x36H{ scanners in your HP-2.
You cannot directly take a list for an SDS or x36HP scanners and load it straight to your HP-2. But what you can do is this:
If you have not already done so, install the Sentinel version for the HP-1/HP-2.
In Sentinel for the SDS and x36HP scanners, pick the Favorites list that you want to use.
From the drop-down File menu, choose "export to *.hpe file".
Sentinel will ask you to select the list you want to export. Select the list, Sentinel will pop-up a window showing the systems in that Favorites list file. If there is one, or more, that you don;t want to export, because they are, say, DMR or NXDN, which the HP-2 cannot handle, deselect any systems that you don't want to transfer and proceed with the export.
Save the exported *.hpe file to a folder you can get to.
Start the Sentinel version for the HP-2 & choose "Import from hpe file (Favorites list).
Sentinel will ask you for what name you wish to use. Specify the list name to use, then proceed.
Sentinel, for the HP-2, will import the System, Site, and Departments from your exported list. It will simply ignore settings from the SDS/x36HP version of Sentinel, such as quick keys, alert LED settings, etc. The base detail for a system, and it's Site and Department, is the same for these two different scanner families.
Note that, if adding an SDS or x36HP to your scanners. you can use an exported file from an HP-1 or HP-2 to get a head start on Favorites for the upgraded scanner. Here again, the basic system, site, and department details are the same. Once you import a list from an HP-1 or HP-2, then you would fill in any other details used by the newer scanner, such as quick keys and Alert led settings,
