NeedtoKnow2
8 months ago in NC mountains, Home Patrol worked well with its stock antenna. It brought in dozens of frequencies in a relatively rural area. Granted, we were at 3,000 feet. But it worked fine in Florida flatlands 2 years earlier just south a few miles of where I live now.
But now in the Ocala, Florida area, flat land at 70 foot elevation, no obstructions, inside or outside, with the same antenna, fresh batteries, with or without USB plugged into the computer or a power supply, or not plugged into anything, and after programming it for stations in the Ocala region, I get nothing except the nearest weather channels. The full database for Florida and the US is installed.
What I mean by "nothing" is this:
I have squelch set at 2 bars and it scans the 100 or so regional stations in the area. It stops on nothing. When I set squelch to 0 bars (no squelch) it will stop on a frequency and just sit there, with static. Nothing but static on any station I stop on. Looking at the power meter as it scans, I do see occasional 2, 3, or 4 bar signals, but even on these, there is nothing but static. No beeps, codes, or anything but static. On a couple of stations, the signal power meter will pulsate on 5 bars (flash on and off every second). But no audible signal except uniform static.
I have fresh batteries. It scans fine. I have it set for my local frequencies, the stock antenna is on. I tried other antennae, inside and outside the house. Same nothing.
Main firmware version is 1.05
Sub firmware version is 1.02
Database version is 08/27.2017
Help version is 07/14/2014
Any suggestions?
I'm kind of thinking that I have a component failure somewhere because this thing is not that complicated.
Any suggestions?
