HP-2: Home Patrol 2 record/replay question
radioguy97
I've noticed since getting my home patrol 2 while it does record just fine you are only able to press the replay button within a few seconds to listen to the recording. I haven't timed it but if you wait over about a minute or two and press replay there are no recordings. Does anyone know how to increase this threshold? In other words, I'd like to be able to press replay and hear recordings for the last few hours. Thanks
Ubbe
Stockholm, Sweden
Max time to wait can be set to 240 sec but you can set the recording to be permanent and then you can go into the menu and review all the recordings and also delete or edit them. Or move them to a computer using its USB connector and it will be much easier to manage and listen as you then can sort on different parameters using the Universal Scanner Audio Player by the RR member Deim.
/Ubbe
