homepatrol-1 metadata
aimedtoannoy
Geneva, Ohio to Temple, TX
Does anyone know the steps for adding metadata to the livestream? the program I use is RadioFeed. (sending audio via Line out port), also maybe make this a sticky if there is an answer. just so other people with the same question don't ask again?
kg4pbd
Click on the Metadata tab across the top of RadioFeed, select radio type, comport, baud rate, and it should start sending metadata. You do need the extreme update on the Home Patrol.
