HomePatrol 2
ve2que
quebec
Is there someone in Quebec who owns a HomePatrol 1 or 2 (got both of them), I am 72 and having a hard time trying to go on trunk. Is there someone can help me with that? Would pay.
Thanks, André VE2QUE
Ronaldski
MI DB Admin
Bay City MI
Regrettably the zipcode scanners come with many years old information in them. Typically I have seen 2014 era, just updated a home patrol 2 not long ago and it had 2014.
To update them to current, use a windows computer, look at the video here. This DOES NOT update favorites list(s) if you use those.
Assuming your area is here- RENIR - Reseau National Integre de Radiocommunication Trunking System, Provincewide, Quebec
Under MODE if it’s D or T it’s in the clear, De or Te sometimes clear, sometimes encrypted, DE or TE is always encrypted.
The T ones can only be picked up by the home patrol 2.
There is very likely a firmware update for the home patrol 1 -
ve2que
quebec
quel systeme veux-tu ecouter ?
j aimerais bien P25 Mais moto ou autre, je les ai tous les deux depuis 3 ans et pas encore réussis a comprendre, merci!
Thanks for the help!
lamarrsy
Rimouski, PQ, Canada
I see by your Amateur call sign you live in the Mauricie area. Not much to listen to out there.
Mauricie County, Quebec (QC) Trunked Systems Only two P25 listed. Hydro Quebec and RENIR
Mauricie County, Quebec (QC) Scanner Frequencies and Radio Frequency Reference the conventional listed here.
Hello mciupa !
When you say “Not much to listen out there”… it all depends on what the original poster want to listen to 😁
Yes he said “trunking” but maybe his interest would widen if he knew a bit more about what is available outside trunking!
in general, in Quebec prov., ambulances and road maintenance (MTQ now MTMD) are on the (trunked) P25 network and fully encrypted. Sûreté du Quebec is currently in its final phase of migrating to the Renir / encrypted, so no luck with these.
But even with these emergency services out of the match, there’s still “other stuff” to listen to. Are they “interesting” or not, only each of us can answer as it is so personal 🫤
Some frequently overlooked “province wide” frequencies that could prove interesting :
- Sécurité Civile du Quebec (Renir P25 *non*-encrypted)
- Marine VHF band
- SOPFEU (forest fires)
- Hydro-Quebec
- aviation band
- FRS/GMRS 22 channels
- amateur radio (CanWarn frequencies are particularly
interesting to monitor when bad weather is forecasted)
And outside RadioReference, there’s also a bunch of other frequencies that can be obtained (keyword “Mauricie”) thru Mckie website : parks frequencies for fishing / hunting, forestry industries, private industries, etc. :
Similar search thru Jonathan Morgan’s tool (the following is an example with Trois-Rivières as the center point with a radius of 100km for the VHF band only) :
Of course most of these would be manual entries to be done, but Uniden Sentinel software is not that complicated to use.
Note that Sécurité Civile, Marine, SOPFEU, aviation, FRS/GMRS, and Hydro-Q freqs/TG are *already* in the Sentinel software database, so, it’s just a matter of activating them for listening use.
‘Hope this helps a bit more !
-Sylvain, VE2LAM
mciupa
Canadian DB Admin
Moderator
I'm here a lot
You are correct. It is subjective what we listen to, just like our music tastes. Not everyone likes the same thing.
He is having a hard time finding things to monitor the point of paying someone to set it up for him.
lamarrsy
Yep, so individually tailored !
I’ll try to help him out with this, no cost.
==> Bonjour André <==
contacte-moi stp (messenger, courriel), je peux possiblement t’aider —mais ça sera sans frais, je ne veux pas me faire payer pour ça— !
Ronaldski
MI DB Admin
Bay City MI
How old is your database in that HomePatrol?
From the main screen, press Menu -->Advanced Menu --> press the scroll down arrow --> Version Information.
ve2que
quebec
2.3 i just that I am not familliar with digital and the setup, I should have move from analog to digital when it begins and was younger hi hi 73's
P25 et aussi le commercial digital (LTR) CLR
