HomePatrol II Tucson Police Talkgroups
mule1075
Washington Pennsylvania
The necessary talkgroups to hear TPD when they setup a patch with TFD are already in the file that I sent you. You can enable TFD by turning on quick key 0. The crosspatch talkgroups are in both the TPD and TFD groups.
Quick Key on a HP-2? Did not know that they had quick keys.
Forty8leap
Tucson, AZ
Kd7eir: Since no quick keys on HP 2, any ideas on how to enable this 15014 Crosspatch channel so it shows up under your TPD Team 4 favorites list on my scanner? The 2 Channels showing under Department TFD Crosspatch are 19012 &19013, thanks for your help.
Forty8leap
Tucson, AZ
An update...I think I’m figuring out how to edit the fav list in Sentinel by editing, copying, & pasting. Then wrote it to my HP 2. Ch 15014 is now showing up under Tucson Police Team 4, TFD Crosspatch. I’ve not actually heard anything on it yet but I’m hopeful.
kd7eir
Tucson, AZ
Since 15014 is the TFD owned talkgroup for the crosspatch, I have that in the TFD group. I'm always listening to TFD and TPD so if they go to 15014 I'll still hear them. I also have 19012 and 19013, which are owned by TPD, in my TPD list for crosspatch.
Forty8leap
Tucson, AZ
When you sent me your .hpe file you mentioned it only had TPD Team 4 enabled...what does that mean and can I enable TFD as well? And how would I listen to both TPD and TFD within that list...would I have Scanner on the main Pima County ...system and avoid everything except those two departments?
kd7eir
Tucson, AZ
TFD is system key 00. I am not sure how you would turn that on in the HP2.
Forty8leap
Tucson, AZ
Kd7eir, if it’s not too much trouble would you be willing to share your TFD Team 4 enabled .hpe file? I’m hearing 19012 & 19013 (from the earlier file you sent) but not TFD Team 4 or 15014 crosspatch.
I really appreciated when you sent me the TPD Team 4 enabled file so I could listen to my neighborhood calls.
