hot box detectors
burner50
The Third Variable
NC Iowa
Most of the ones around here talk after every train goes over. Here at work, I hear only a single CSX detector constantly. At home, I hear that detector, another CSX detector, and a couple of NS detectors. I kind of miss the NS detectors giving the axle counts. Every so often, the number would be shockingly beg.
I have a radio that's RR only, and when I hear an NS detector in Butler, IN on 160.800, that is my cue that the 2M band is open.
Most I've ever had was 724 axles.
172 cars and 6 motors (12,000 foot long manifest). What a pain in the rear
burner50
The Third Variable
NC Iowa
At least the HBD gave you an "even" numbered axle count. he he he
The majority of the detectors around here, dont give a count unless there is a defect.
Most give a highball and a temp... Theres special problems when you get an inaccurate axle count from a defect detector and we have AEI Readers all over.
ratboy
Toledo,Ohio
I heard and saw 812 once, a CR train, with 7 Dash-8's and a new UP SD-70 in the lead. It crawled past and took forever to clear the crossing. Mostly hoppers but it had some empty stacks on it too. Biggest I ever heard period was 840. I always wondered what it was. That was on NS before the CR split.
kamikaze1
greenwood sc
i pick up 2 at miles post 422.9/402.9
they sound like this
CSX equipment defect detector mile post 422.9 then go silent for a bit depending on train length then comes back CSX equipment defect detector mile post 422.9.. no defect.... total axles 448...... end of transmission
