how can i decode this data from a motorola dmr system
dwabbit
how can i decode these data packets
I believe it may be GPS location data on a motorola dmr system
cheers
Code:
2022.06.16 12:41:48  Activity update:  Slot1=Indiv Data  Slot2=No Activity
2022.06.16 12:41:48  +DMR           slot1         BS DATA  ERR1 DCC=3  Data Header DPF=[2:UcData] Tgt=131 Src=64250 Conf=0 SAP=[4:IP Data] Blocks=3 Pad=1 Last=0 Seq=0
2022.06.16 12:41:48  +DMR                slot2    BS DATA       DCC=3  Idle
2022.06.16 12:41:48  +DMR           slot1         BS DATA       DCC=3  Rate 1/2 Data 45 00 00 1F B4 16 00 00 40 11 B2 3A  E.......@..:
2022.06.16 12:41:48  +DMR           slot1         BS DATA       DCC=3  Rate 1/2 Data 0D 00 FA FA 0C 00 00 83 0F A5 0F A5  ............
2022.06.16 12:41:49  +DMR           slot1         BS DATA       DCC=3  Rate 1/2 Data 00 0B 58 0F 00 01 74  ..X...t ARS; Tgt=131 Src=64250
2022.06.16 12:41:49  +DMR                slot2    BS DATA       DCC=3  Idle
noamlivne
If you are using DSDPLUS Fastlane it is supposed to do that for you automatically (providing it knows the code, it is not encrypted, and there are no errors).
But in your case it is not a location, but an ARS data stream (DMR shows ARS; in purple) and the program wrote it down for you:
"ARS; Tgt=131 Src=64250"
