How do I toggle Zip Code Scan on SDS100
w8prr
WEST LIBERTY
Very stupid question, but can someone tell me how to toggle the Zip Code scan on and off on my SDS 100, and for that matter on my '36 scanners also? Sorry to be so dumb for as long as I've used Uniden scanners, butt I need help!
letarotor
Arlington, TX
On the topic of zip codes, and especially in the US, this link is helpful if you have a mobile device with GPS in it like a smartphone. It will tell you what ZIP code you're in and I used it a lot before I bought the GPS unit for my scanners.
https://www.whatismyzip.com/
Sent from my SAMSUNG-SM-G930A using Tapatalk
w8prr
WEST LIBERTY
Interesting, will check out, but how the heck do I turn zip code scan on and off?
Hit_Factor
Saint Joseph, MI
You can create a FL that has location control enabled or disabled.
Maybe if you explained your goal?
UPMan
In Memoriam
Arlington, TX
The scanner will always apply the currently set location to determine what is scanned from the main database and any FL that has location control enabled. There is no "turn on" or "turn off" for this.
ecarvalho
To enter your zip press Zip/Services
Sent from my iPhone using Tapatalk Pro
phask
zanesville
You need to explain what you are trying to do - there is no off and on, but there are favorite lists and full database.
w8prr
WEST LIBERTY
Talked to Uniden support this afternoon and the answer was simple, just turn full database off or on, works fine.
Thanks to all who replied.
UPMan
In Memoriam
Arlington, TX
So, I suspect your actual question was "How do I scan only my own Favorites Lists and not the Main Database?"
