How does Capacity Plus work?
apx7000xe
GA/SC State Line
I thought there was a TRBO forum but apparently there isn't so I figured this would be the most appropriate place to ask. There doesn't seem to be a lot of information out there about how Capacity Plus and I have a few questions about how it compares to other types of trunking. First off do they affiliate with a system controller or do they passively monitor the rest channel until they receive a call on the talkgroup or transmit? What is the advantage over Capacity Max or the discontinued Connect Plus systems? Are these systems managed by an admin console with the ability to inhibit other radios like P25 or NXDN? Is using RAS the only way to keep anyone from programming a radio onto a system or do they use a system key to enable trunked programming?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Since these are all Motorola protocols, the Motorola forum is the most appropriate.
KK6ZTE
California
Capacity Plus is a lightweight "trunking" system. It's much easier to implement as is comparable to a modern version of an LTR system.
Cap+ doesn't require FB8 channels like a true trunking system with a controller, it's a distributed architecture and the rest channel rotates through the repeaters. You can have single or multisite Cap+ systems.
Cap+ is cheap and works well, but you don't have the admin features you get with P25, NXDN trunked, maybe CapMax?--I'm not familiar with that product.
I have two three site systems I maintain, it's lightweight and works fantastic for what it is--a replacement for our LTR systems that I can upgrade as customers migrate. I wish there was a way to get competitive radios onto the system, so that Motorola had to be competitive, but that won't happen.
Obviously CapMax does a whole lot more but it's much more expensive, requiring a lot more planning and hardware to implement. Most industries don't need that complexity, usually only large SMRs will use it.
apx7000xe
GA/SC State Line
I'd personally like to see Capacity Max take off. There's even less info out there on it than there is in Cap+ but from my understanding it's very similar to P25 Phase II. If it allows the admin features and is run without the proprietary Motorola features it would be an excellent alternative for public safety agencies that can't afford to implement P25 and not be stuck with one vendor.
KK6ZTE
California
CapMax is DMR Tier 3 with proprietary features. A pure DMR Tier 3 system would be a far better choice, but again, it's a larger system. Not to mention, it's not "public safety grade". It's school bus and trash truck grade, which unless you have an enormous system, Cap+ works great for.
apx7000xe
GA/SC State Line
Correct about not being public safety grade but counties that only have a $12 million dollar per year budget can't afford to drop $6 million on a P25 system when you can get basically the same thing in DMR or NXDN for $1 million or less and if you ask the taxpayers to help you out, they will vote it down in a heartbeat because they don't know the difference and nobody wants to give the government more of their money. Currently fighting this battle right now in my county.
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
Connect Plus has been discontinued. Cap max may not be "public safety" grade, but I have installed several for city/county wide public safety agencies. Like noted above, it is a value proposition where you get x features for y dollars. MOTOTRBO gets the same features as p25 for about 10% of the price. TT
IMPRES2
+1 for TT’s comment
Cap max may not be "public safety" grade, but I have installed several for city/county wide public safety agencies. TT
CapMax has a lot of features similar to an L-Core ~ just dumbed down to keep governments from jumping ship from P25 to TRBO based on price-point (as you are considering).
If you have a local Motorola PCR channel partner in your area that has a CapMax system you should ask to see the management side in action. I work for a channel partner that has three deployed CapMax systems and we bring customers through our demo lab where they can go hands on with the different platforms we offer.
Correct about not being public safety grade but counties that only have a $12 million dollar per year budget can't afford to drop $6 million on a P25 system when you can get basically the same thing in DMR or NXDN for $1 million or less... Currently fighting this battle right now in my county.
TampaTyron
Phoenix, AZ
Admittedly, I am a Motorola DMR fan. However, you really need to buy the relationship with the local shop who would be supporting the system. If the local KW guy is top notch, but the local M guy is trash then you would be better served by the KW guy. In my world, local shops are all over the place in regards to capability. It is often my job to go in and smack them down (in as nice a way as possible) in order to get customers better or working systems. TT
